E180 LCD has stopped working
Posted: Wed Jul 03, 2019 6:38 pm
by AleB737
Hello, today after finishing a print, on the LCD, a message appeared that said: "incorrect calibration" (or something like that, now I can't remember perfectly), and there was a button with an "Ok" to press . I tried to press it two or three times, and at a certain point, the printer restarted. Now the LCD is on and shows the main screen, but does not respond to any touch. I tried turning the printer on and off, but nothing changed. The firmware is updated to the latest version. Do you know what I could do?
Re: E180 LCD has stopped working
Posted: Thu Jul 04, 2019 9:27 am
Hi,you can check if the screws on the screen link are loose.
Posted: Thu Jul 04, 2019 5:10 pm
by AleB737
Hi, the screws seem narrow to me. Isn't there a way to start the screen calibration via the PC?
Posted: Thu Jul 04, 2019 5:19 pm
What is the screen calibration you are referring to? I mean maybe the screen screw is too tight and the screen is not responding.
Posted: Thu Jul 04, 2019 5:25 pm
by AleB737
Now I tried to slightly loosen the screws, but nothing changed. What I mean is if there is a way to reset it via the PC
Posted: Thu Jul 04, 2019 5:33 pm
Posted: Fri Jul 05, 2019 5:47 am
by AleB737
I tried to do everything the topic says, even doing everything that is done in the video, but it doesn't work. The screen turns on but does not respond to touches
Posted: Fri Jul 05, 2019 9:00 am
Hi, You can contact your sales to change the screen.
Posted: Fri Aug 02, 2019 9:10 am
ZIM372019 wrote:
Thu Aug 01, 2019 10:51 pm
Hi, very good idea, but it seems impossible.
You can contact your sales to make a screen change.
Posted: Thu Nov 19, 2020 7:06 pm
by Feltner1
I have exactly the same problem. Anyone got a suggestion?
