Prusa I3 Pro B fails
Bernd
Re: Prusa I3 Pro B fails
Post by Bernd » Tue Jun 21, 2016 5:14 pm
you can not put pressure on the filament and it can thus also not be pushed by the gear
Post by William » Tue Jun 21, 2016 5:39 pm
Bernd wrote:yes you are right i can push the filament without the wheel rotate ! Although, if I do this with the engine built state rotates the gear from the motor but the filament remains on the spot.
That is to say,the gear doesn't drive the filament to the nozzle at all when extruder motor runs ?am i right ?And their gap is like the pic i posted on your extruder? If i'm right,i believe you can adjust the gap between the two wheels and the filament. :D
Bernd
Post by Bernd » Tue Jun 21, 2016 5:44 pm
Yes you are right ! But how can I adjust the gap? I have not seen to adjust anything
Bernd
Post by Bernd » Tue Jun 21, 2016 5:46 pm
maby the wheel have a wrong size ? or the gear ?
Post by William » Tue Jun 21, 2016 5:55 pm
Bernd wrote:maby the wheel have a wrong size ? or the gear ?
Eh,i think its the spring.I dont know if your spring had some mistakes,cuz the gap will change once you press the handle,isn't it?
Bernd
Post by Bernd » Tue Jun 21, 2016 6:26 pm
when I press it, the gap is larger that's right, but I can not push it upwards'm afraid that I the lever terminating
Post by William » Mon Jun 27, 2016 5:13 pm
Bernd wrote:when I press it, the gap is larger that's right, but I can not push it upwards'm afraid that I the lever terminating
Hey,buddy
Have you solved your trouble already?
Bernd
Post by Bernd » Mon Jun 27, 2016 6:27 pm
No , sorry... i must wait for the parts ! i can do nothing ... grrrr
Post by William » Tue Jun 28, 2016 1:45 pm
Bernd wrote:No , sorry... i must wait for the parts ! i can do nothing ... grrrr
Alright,waiting for your good news.
Bernd
Post by Bernd » Wed Jul 27, 2016 5:01 pm
Hi William,
after change the parts i can print... juhuuuu look at this Video it´s not perfekt but i thinks i must change the settings a little.
https://www.youtube.com/watch?v=ZrdCmcSNiOA
