I put the 3d touch on my geeetech a20.
I have updated the firmware and the 3d touch works.
I'm having trouble adjusting the offset.
Once set: auto home then control with the z + sheet of paper.
I redo my corners then an autonomous for flush control.
I start printing and the nozzle is either too high or too base and I cannot print.
I tried dozens of settings in vain
Can you give me a tip because I can't do it.
I missed a step is not possible
3d touch setting
Re: 3d touch setting
Hi, you can refer to this:viewtopic.php?f=27&t=18371
Hope to help you.
Hope to help you.
Thanks a lot! I'll try that out.William wrote: ↑Mon Apr 20, 2020 5:37 pmHi, you can refer to this:viewtopic.php?f=27&t=18371
Hope to help you.
