A10M EEPROM
master2sid2
A10M EEPROM
Post by master2sid2 » Mon Aug 19, 2019 9:44 pm
Hi. I need some help.
I think I'm reset the EEPROM in my new a10m printer. Now I have a problem with printing, Y-axis offset, stucking bed by home command, uneven first layer. Can anybody make a screenshot from EEPROM of your printer?
Re: A10M EEPROM
Post by William » Tue Aug 20, 2019 9:31 am
Hi, does the y-axis offset you refer to be layered when printed?
You can try 1. Check the belt tightness;
                  2. Whether the bearing and the pulley are issued (the card can be lubricated for lubrication);
                  3. The printing speed should not be too fast, the reference range is 30-60mm/s;
The hotbed needs to be leveled before printing.
master2sid2
Re: A10M EEPROM
Post by master2sid2 » Wed Aug 21, 2019 3:08 am
I guess that I have found the reason. One of the table wheel bearings is jammed. Thanks for your help.
Re: A10M EEPROM
Post by William » Wed Aug 21, 2019 9:20 am
:D
