Z-Axis moving too far
Breslin
Re: Z-Axis moving too far
Post by Breslin » Fri Feb 15, 2019 2:46 pm
I had been trying for the past year to get this working. The update was ok but adding Gcode: "M92 Z400" command and the Gcode: "M500" to save all worked perfectly.
Murphyprecht
Post by Murphyprecht » Thu Feb 28, 2019 4:43 am
Great advice, would you know what M92 should be posted if it doesn't have the T8 lead screws? Cheers
vujsa
Post by vujsa » Tue Apr 09, 2019 3:15 am
This fixed my problems!
I had actually used M206 to set the Z-axis offset but then my models were printing about 800% too tall.
Here is the M206 documantation:
http://marlinfw.org/docs/gcode/M206.html
If you used that, then you'll need to set the offset to zero when you fix the steps/mm issue with M92.
Now I can do all the other stuff needed to get my prints to come out correctly. :D
vujsa
Post by vujsa » Tue Apr 09, 2019 4:26 am
After further tinkering and testing, I found that I actually needed the steps/mm and z-axis offset to get things working properly.
So if you find that neither correction fixes the issue, you may need to do both.
