Looking for some advice please...
I'm trying to hook up the Geeetech Voice Module to the Pro Micro using the TX/RX pins on the Arduino (1 & 0 respectively) but am having no luck getting the module to work.
From the vr_sample_check_baud_rate example with pins changed:
Code: Select all
#include "VoiceRecognitionV3.h"
* Connection
* Arduino VoiceRecognitionModule
* 2 -------> TX
* 3 -------> RX
VR myVR(0,1); // 2:RX 3:TX, you can choose your favourite pins.
Check baud rate failed.
Please check the connection, and reset arduino
Tried using Softwareserial.h to assign other pins, still the same.
Is the Pro Micro even able to use this module? I can't find anything that helps, and have searched around a lot.
Any ideas/pointers/help ??
