I have Windows 10.
Slicing seems to start correctly. Before the progress display starts, the EasyPrint3D program breaks down completely. Without an error.
The button Done! I can’t click. The gcode file is also not yet created.
What can I do?
EasyPrint3D aborts when slicing - without an error message
- slicing_abord.png (147.8 KiB) Viewed 21925 times
Re: EasyPrint3D aborts when slicing - without an error message
Hi, can you provide your stl?
and you can try slice another model.
you can use Repetier Host to slice.
Hi William
the program always stops with the *.stl:
Program example files: deer.stl, case.stl
ASCII: comp01.dae_A.stl, test3.dae_A.stl
Binary: comp01.dae_B.stl, test3.dae_B.stl
I think the problem is not with the files.
I am a newbie.
What you mean with "... use Repetier Host..."
With Ultimaker 4.5 I can create the *.gcode files from the *.dae files. There are no problems.
Regards Juergen
I am a newbie.
Regards Juergen
- test3.dae_B.stl.png (191.51 KiB) Viewed 21873 times
- dateien.zip
- (18.11 KiB) Downloaded 499 times
Hi Wiliam,
I reinstalled the EasyPrint 3D program and the printer driver.
The result is the same. Slicing stops without an error message.
Wenn ich das Slicing mit Ultimaker Cura 4.5
If I do slicing with Ultimaker Cura 4.5 then I can easily load the *.gcode file.
I have linked the *.gcode extension to the EasyPrint3D program.
When I double click on a *.gcode file I get an error message:
System.IO.FileNotFoundException: img/Disconnect.png
bei System.Drawing.Image.FromFile(String filename, Boolean useEmbeddedColorManagement)
bei RepetierHost.view.ThreeDControl.UpdatePrintPanel(Object sender, EventArgs e)
bei System.Windows.Forms.Timer.OnTick(EventArgs e)
bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The program can then no longer be continued.
I would be very happy to receive a response.
Regards Juergen
Regards Juergen
- Errormessage.png (21.69 KiB) Viewed 19890 times
