command waiting
alex.abate
command waiting
Post by alex.abate » Mon Nov 27, 2017 3:04 am
Hi, I started printing using repetier hosts and everything was fine, half of a job started to give error messages and after the printer give the message "command waiting" and doesn't move. I try to replace the firmware but nothing change.
Re: command waiting
Post by William » Mon Nov 27, 2017 11:59 am
Perhaps the reason for the USB cable, you can try to print with an SD card to see if the issue is solved.
alex.abate
Re: command waiting
Post by alex.abate » Wed Nov 29, 2017 5:03 am
thanks William I'll try. Now the new thing is that the machine, after waiting message, loose the heating plate and the second extruder temperature is 100°C without command.
Re: command waiting
Post by William » Thu Nov 30, 2017 6:44 pm
Could you upload pictures of the wiring of mainboard?I also need to confirm what is displayed on the monitor.
alex.abate
Re: command waiting
Post by alex.abate » Fri Dec 01, 2017 5:16 am
Hi, I print from SD and everything works right. still the problem with PC.
How can upload an image?
thanks
Admin
Re: command waiting
Post by Admin » Fri Dec 01, 2017 12:01 pm
I think there may be the COM port is occupied in the middle of printing, of course, may also because of the USB cable and the interface.
