Me Creator 2 Firmware update
Batfinks
Post by Batfinks » Sat Jul 01, 2017 9:22 am
When I use Arduino to attempt to update the firmware I get a compile error:
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Marlin_main.cpp:47:0:
sketch\language.h:36:0: warning: "MACHINE_NAME" redefined
#define MACHINE_NAME "MeCreator 2 "
In file included from sketch\Marlin.h:22:0,
sketch\Configuration.h:6:0: note: this is the location of the previous definition
#define MACHINE_NAME MECREATOR2
sketch\Marlin_main.cpp:2678:36: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
from sketch\cardreader.h:8,
struct fpos_t {
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
exit status 1
Re: Me Creator 2 Firmware update
Post by William » Tue Jul 04, 2017 2:11 pm
there are some problems in defining name without using string,such as“ #define MACHINE_NAME MECREATOR2 ”which should be replaced by“ #define MACHINE_NAME "MECREATOR2" ”
Flitterm
Post by Flitterm » Thu Nov 02, 2017 6:58 am
When trying to install the 3DTouch auto leveling sensor, I had problem to compile the Marlin code on Arduino IDE and got the error:
( GT2560 rev-A board )
I found the solution on the Arduino forum.:
In your Arduino IDE go to
1. Tools > Board > Boards Manager... > Arduino AVR Boards(click on it) > select 1.6.11 from the "Select version" menu > Install
2. After installation completes click the "Close" button
Now you can compile!
The problem is caused by the new compiler version included with Arduino AVR Boards 1.6.12 and later, it is more picky about the bad code that someone wrote. You will need to avoid upgrading to any Arduino AVR Boards version above 1.6.11 until someone fixes the problem in the Marlin code.
Hope this can help others
