Help 3dtouch auto leveing
Posted: Sat Jun 24, 2017 1:54 pm
Good morning, I recently installed a 3Dtouch sensor on my i3 pro b printer.
You have been running 5 impressions.
The sensor is faulty. It ejects the sensor axis, but can not re-enter, so the alarm is activated.
I've made the critical point adjustment, as specified in the abnormal video performance.
I checked the voltage between the cable, Brown (-, GND) and red (+ 5V) and it is correct.
Could it be a problem with the orange control cable?
Or from my GT2560 will not generate the signal on the orange control cable.
How can I check if the board generates the signal correctly?
I tested with the Repetier Host using the code M280 P0 S160 the alarm was disabled. With the codes M280 P0 S10 works and ejects the sensor.
But the M280 P0 S90 does not succeed in causing the shaft to retract.
And then the alarm is triggered.
https://youtu.be/0r9wSq4MXOs
