Can't Save Files
AbeFM
Can't Save Files
Post by AbeFM » Wed Jan 11, 2017 2:10 am
I get an error anytime it tries to save anything - access to path c:\Program Files(x86)\Geeetech\Easy Print\work\composition.obj' is denied, and I get a similar error for the other files it tries to save.
Code: Select all
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\Geeetech\Easy Print\work\composition.obj' is denied.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.IO.File.Open(String path, FileMode mode)
   at RepetierHost.model.geom.TopoModel.exportObj(String filename, Boolean withNormals)
   at RepetierHost.view.STLComposer.saveComposition(String filename)
   at RepetierHost.view.STLComposer.buttonSlice_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.8745 (WinRel.050727-8700)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
EasyPrint
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Geeetech/Easy%20Print/EasyPrint.exe
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.8750 (QFE.050727-8700)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1664.6217
    CodeBase: file:///C:/Program%20Files%20(x86)/Geeetech/Easy%20Print/OpenTK.DLL
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.8763 built by: WinRel
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
OpenTK.GLControl
    CodeBase: file:///C:/Program%20Files%20(x86)/Geeetech/Easy%20Print/OpenTK.GLControl.DLL
System.Data
    Win32 Version: 2.0.50727.8751 (QFE.050727-8700)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Curiously, the list of "recent files" was the same from Repetier.
I'm looking forward to this program working, it seems easier to make tweaks before a print.
Also, I'm getting the buttons appearing off the edges of any pop-up windows, I've seen someone else mention this already.
Win10
bang
Re: Can't Save Files
Post by bang » Fri Jan 13, 2017 3:02 pm
AbeFM wrote:I get an error anytime it tries to save anything - access to path c:\Program Files(x86)\Geeetech\Easy Print\work\composition.obj' is denied, and I get a similar error for the other files it tries to save.
Code: Select all
mscorlib
EasyPrint
System
System.Drawing
OpenTK
System.Xml
Accessibility
System.Core
OpenTK.GLControl
System.Data
enabled.
For example:
<configuration>
</configuration>
Win10
You can try installing easyprint to other disks not disk C,and run the software as administrator.
AbeFM
Post by AbeFM » Fri Jan 13, 2017 3:50 pm
I already tired running as admin, with no help.
I can try the reinstall soon.
bang
Post by bang » Fri Jan 13, 2017 4:04 pm
OK,remember to install it on other Disks.
