Mk8 Extruder - filament jams in the throat.
benedetto.luca
Re: Mk8 Extruder - filament jams in the throat.
Post by benedetto.luca » Thu Aug 11, 2016 1:57 am
I’ve do some test and my idea that the barrel are not cooled enough was confirmed!
I’ve design a specific update to my customization in order to redirect the MK8 fan air versus the barrel, so versus the cooling zone:
Mono Extruder In Place B.jpg (410.26 KiB) Viewed 26175 times
With this I finally am able to print “strange” PLA that ask more degrees, with retraction!
You can find on my http://www.thingiverse.com/thing:1708971 like all other componets of my customization!
Lami René
Post by Lami René » Sun Dec 11, 2016 10:55 am
Bonjour,
You will find the original text translated into English following this original French text.
J'ai acheté le 24 septembre 2016 une imprimante delta Geeetech Rostock 301 (M301) qui a beaucoup de problèmes de conception. Alors cela ne concerne pas nécessairement que vos problèmes.
Mais dans le sujet suivant, vous trouverez peut-être des pistes de solution que vous pourriez appliquer à votre cas :
http://www.geeetech.com/forum/viewtopic ... 27&t=18578
Cordialement,
L'ami René
I bought on September 24, 2016 a Geeetech Rostock 301 delta printer (M301) which has a lot of design problems. So it does not necessarily concern your problems.
But in the following topic, you may find some possible solutions that you could apply to your case:
Cordially,
Friend René
One for all and all for one !
Soadyheid
Post by Soadyheid » Thu Jul 20, 2017 6:21 am
you can try fitting a weaker spring in the filament pinch mechanism. The one which came with my printer was too strong and caused the motor to stall (click noise) I fitted a weaker one and ordered an aluminium mechanism which allows you to adjust the pinch pressure.
With the aluminium pinch mechanism fitted and adjusted, no more problems, filament feeds perfectly! :D
Play Bonny!
Soadyheid
