Problems with printing PETG
DzzD
Re: Problems with printing PETG
Post by DzzD » Sun Oct 27, 2019 2:03 am
Maybe you can try to tight the extruder gear, on an A20m, which have two extruder, I was getting this kind of default on one color, and it was because the filament was slipping on the extruder gear.
There is a screw on the extruder for the gear tension. Look here viewtopic.php?t=61882
Jarda3d
Post by Jarda3d » Sun Oct 27, 2019 8:29 am
Same effect I was get today, but it is due bad PTFE tube...
13mm3/s was too much...
10mm3/s was too much...
8mm3/s was too much...
6mm3/s was too much...
Maybe tube is "overused", but filament does not want to go through easily via tube alone and make waves inside tube. Like it is not PTFE?
A10 Slic3r profile: here
