Sanguinololu Mosfet burn out
Lamo
Post by Lamo » Tue Dec 24, 2019 9:01 pm
Hello everyone,,
So i just bought a Geeetech i3 Pro B and finally finished building it, only to do a test run on the heaters to check if they were working, the extruder worked a charm however the heat bead( MK2a) i was heating to 50 degrees, at about 45 the mosfet started smoking... so disconnected, and now the mosfet just constantly supplies current, and everytime i connect the heat bed same thing. I've done some reasearch and its because my heat bed has only .8ohms resistance and not 1.3-2ohms causing nearly 15.5 amps to run through the mosfet hence burning out. Now i bought it on ebay, and have requested to have the Sanguinololu board and the heat bed replaced ( the seller just imports them... so hopefully he says yes, others wise i have to pull it all apart and send it back). Now question http://tradevenue.se/ is, when/ if i get an new board and heat bed, how do i stop this from happening, in case the heat bed still has low resistance around the 1 ohm mark?
I'm only new to 3d printers, and really want to get this working, i have had a few other issues related to firmware, and getting it to work on mac and also arduino but i'm slowly getting there...
if someone could please help!
Re: Sanguinololu Mosfet burn out
Post by William » Wed Dec 25, 2019 9:20 am
:D Hi, at present, the motherboard corresponding to PRO B models is the motherboard of GT2560 A +.
If the resistance of the hotbed is too small, printing may be affected.
When you change the hotbed, you can first measure the resistance of the hotbed. It's about 1 ohm.
