PS: rmrodriges ... this is also appearently your Problem with the Display as well, please check it yourself before modifying it with your multimeter...
Hopefully this helps you!
LCD 12864 with GT2560
Re: LCD 12864 with GT2560
Yep. it should be the same problem because the vendor is the same.
Did you change the connectors position? Could you post some photos please?
Many thanks.
RMRodrigues.
Many thanks.
RMRodrigues.
Hello again,
Yes, for the LCD12864 from bigtree-tech the connectors should have been mounted 180° turned, but here I have a modification.
All you have to do is just to turn the cable connectors 180°.
Still, please do the checks with a multi meter before retrying, I take no responsibility if it is not working for everyone !!
Be warned and measure first before damaging your equipment .
I just know it worked out for me and with the bigtree-tech LCD12864...
In the attachment is a small image, which might help...
Best regards,
Raisa
Best regards,
Raisa
- Modification... do at your own risk !
- Mod_LCD12864_bigtree2.jpg (291.36 KiB) Viewed 19803 times
Hi there,
As Raisa suggested me, I've turned the connector 180 degress and it's working fine now.
Many thanks Raisa.
Cheers.
RMRodrigues.
Many thanks Raisa.
Cheers.
RMRodrigues.
has been a pleasure to help
Hi Raisa
i am getting same problem.Please let me know should i cut all the wires and rotate 180digree connection ? or cut and swap frist pin and last pin?
thanks
Shiva
thanks
Shiva
Thanks Raisa,
I have done it,Started working
Hi All
I am having the same problem a blank screen and a red led number D8 by the heater 2 connection on my GT2560. I know it is an old thread but if any one can help I really do need it,,,
Could you post some pictures showing the details?Scooby wrote:Hi All
Thanks to everyone who cleared up the reversed pins issue, solved my issue with the Big Tree board.
Thanks!
Mike
Chattanooga, TN
Thanks!
Mike
Chattanooga, TN
