Newbie with a problem A10m
thoffmann
Post by thoffmann » Fri Oct 18, 2019 8:44 am
Just finished assembling my new A10m but when I turn the power on at the power supply nothing happens. screen stays blank? is it something I did?
thoffmann
Re: Newbie with a problem A10m
Post by thoffmann » Fri Oct 18, 2019 8:57 am
ok so I did a stupid stupid thing forgot to set the asm to 120 ugh sorry yet thanks
Post by William » Fri Oct 18, 2019 9:20 am
:D Hi,If the screen is still not lit after you turn on the printer now,
Can try:
1. Check if the power supply can be powered normally.
2. Reconnect the screen cable;
3. Check if there are three lights on the motherboard.
V3 三灯亮起的位置.jpg (1.51 MiB) Viewed 8263 times
thoffmann
Post by thoffmann » Fri Oct 18, 2019 11:27 am
got it working by my Y axis makes a horrible noise and skips any idea how to fix this?
Post by William » Fri Oct 18, 2019 11:36 am
Hi,Can you describe the problem specifically?
Or provide a specific video,
So that we can solve the problem better.
Jarda3d
Post by Jarda3d » Sat Oct 19, 2019 10:06 pm
check and tight all screws...
If still, then you measure and check/set driver voltage, it is easy.
A10 Slic3r profile: here
Users browsing this forum: No registered users and 6 guests
