Print sequence not correct
Jleach12
Post by Jleach12 » Sun Mar 12, 2017 12:18 am
I am a beginner. I bought the delta rostock g2s. I have it assembled and calibrated. Upon starting my first print, it heats the bed, homes, goes to 5mm and the extruder heat. After this, it raises to about halfway point and starts printing. There is also very little coming out of the extruder. Could someone point me in the right direction?
Frank_Hon
Re: Print sequence not correct
Post by Frank_Hon » Mon Mar 13, 2017 10:57 am
first,you should level the hotbed when you finish assembling.
then,as to the extruder just coming out a little,there's a post where you can do some trobleshooting.
viewtopic.php?f=19&t=17097
hope this can help you. ;)
