Noisy Z axis
Rege
Noisy Z axis
Post by Rege » Tue Nov 15, 2016 2:47 pm
Hello after mounting my i3 Pro B , i have a problem with the Z axis
Move is really noisy, and seem hard for the stepper motors (even if it moves as commanded by Repetier Host)
Is there a need to grease or lube the Z axis nut and threaten rod?
And for the linear bearings and smooth rod?
Regards
Re: Noisy Z axis
Post by William » Tue Nov 15, 2016 6:12 pm
Here's a post about the z axis issues, please check it, see if it's helpful to you:
http://www.geeetech.com/forum/viewtopic ... 22&t=16917
1.You need to make sure the hole at the top is not so tight for thread rod.
The rod is installed well in the coupling.
The rod itself is all not bent without any broken threads.
2.You can swap the driver on Z axis with the one of one working motor,and check if the motor wiring has a good connection:
3.The driver has a problem
Check this:
Rege
Re: Noisy Z axis
Post by Rege » Tue Nov 15, 2016 9:26 pm
Thanks for answering
I will check the links provided but I think a misunderstanding :
It works it is just noisy and seem to be hard for the motor
I will try to make a video tonight.
Rege
Re: Noisy Z axis
Post by Rege » Wed Nov 16, 2016 4:27 am
Hello
please find a video to explain: https://youtu.be/u6lSNP0Uhiw
Rege
Rege
Re: Noisy Z axis
Post by Rege » Wed Nov 16, 2016 5:23 am
The X axis makes noise too , coming from the linear bearings
For Z axis the noise is mainly from the screw.
Rege
waldamore
Re: Noisy Z axis
Post by waldamore » Sat Jan 21, 2017 3:48 am
i also had the issue of partly blocked x-axis.
then i printed two of these any the rods can spin freely now: http://www.thingiverse.com/thing:1920478
also my print quality increased a lot!!
good printing :-)
