Hello! Just recieved the prusa i3 kit with Iduino Mega 2560 + RAMPS 1.4 board and lcd 2004.
I can't seem to find the wiring scheme for the electronics and extruder anywhere! Supplied on you
website is only the mounting instructions for the mechanical parts. I saw i a earlier post that
someone got the wiring instructions mailed to him, can i have the instructions too please?
email: fladerbacken01@gmail.com
Prusa i3 with Iduino Mega 2560 + lcd 2004
Re: Prusa i3 with Iduino Mega 2560 + lcd 2004
after a closer look at all the parts it seems to br straight forward so i think i'll manage, also found the ramps page on your wiki. Bad searching from my side
- techsupport
- Site Admin
Hi saxomophone
Please refer to the following link. the electronic parts connect.
http://www.geeetech.com/wiki/index.php/Ramps1.4
The appended drawings have a clear connection.thank you.
Best regards!
Best regards!
- Ramps1.4 connect .rar
- (96.51 KiB) Downloaded 671 times
Email: forum@geeetech.com
Hello again. I have now started with the electronics, and it doesn't seem to be a thermistor for the heatbed included in the kit. On the heatbed is two smd leds and a smd resistor pre-soldered. Is the thermistor missing from my package or is it so that the heatbed-thermistor is an smd-version already soldered on the heatbed, and if so: how is the wiring for the heatbed?
Regards!
Regards!
- techsupport
- Site Admin
Dear saaxomphone
sorry to late reply, Because thermistor is small, not easy to find, you check your package carefully and the ground.
If you still can't find, you can send a picture of your packaging, we will give you a satisfactory answer.
waiting for your repely, thank you. Best regards!
Hello. I've thoroughly searched the package and the thermistor is definitely
not there, but i found that an electronics-shop near my home have equivalent thermistors in stock
so i've got some from there. Regards.
