Color mixing gcodes for Mixbot
Thompson798
Post by Thompson798 » Fri Oct 25, 2019 3:10 pm
For the new Mixbot is it possible implement the mixing behavior as gcode ? There are defined codes for this: M163-M165. I will buy the printer, if a software change of the mixing behavior will be possible.
Regards
Re: Color mixing gcodes for Mixbot
Post by William » Fri Oct 25, 2019 3:25 pm
:D Hi,If you are referring to mix color,
You can view this software: https://www.geeetech.com/download.html?download_id=40
Import gcode and set it in scope according to your needs.
I hope this can help you.
