Locked
Post by William » Tue Dec 04, 2018 5:00 pm
fanteoz wrote:
Sat Dec 01, 2018 5:23 pm
salve a tutti sono nuovo del forum e delle stampanti 3d ho un piccolo problema sul asse z, iniziamo a dire che ho una I3 pro W assemblata da me ho scaricato il firmware e installato con arduino 1.0.6 ma avendo le barre filettate 8 dovrei lanciare il Gcode M92 Z400 e poi .500 per salvare ma non ho idea da dove iniziare per reperire questi Gcode e come installarli nella stampante
il problema è l'altezza dell'asse z che si alza troppo e non rispetta i MM correti
mi dareste gentilmente una mano che sto impazzendo da una settimana in rete non c'è una guida chiara su cosa fare
GRAZIEEEEEE
Try to use the Repetier-host
1.Set the correct baud rate and connect it
2.Then you can send it via Manual mode
RaySkye
Post by RaySkye » Tue Dec 11, 2018 7:08 am
Couldn't just put a version out there that has instructions like "Click the button" no.
Have to have steps like "Align the 12 stones of power on the altar of midnight".
/sigh
Fine.
I guess.
ColPaul
Post by ColPaul » Sun Dec 16, 2018 11:27 pm
I just finished assembling my i3 Pro C last night. I am able to connect from my Mac using Repetier-Host, home all the axes and autotune extruder (at least extruder 0). I wanted to change the PID constants in the firmware, but the latest version I can find in this thread for a i3 Pro C is v1.0.03. The printer reports it is on V1.0.5. I did find V1.0.5 for M201. Where can I find it for i3 Pro C?
Post by _kaktus_ » Mon Dec 17, 2018 2:22 am
:mrgreen:
Have you looked here :?:
ColPaul
Post by ColPaul » Mon Dec 17, 2018 4:33 am
Thanks, I had not looked there. However, I am looking for the source code for Arduino to compile with new configuration.h that I can tune. Your link appears to only have the precompiled binaries and only up to v1.0.4. Still on the hunt for the original source code for v1.0.5 for i3 Pro C.
Paul
Post by William » Mon Dec 17, 2018 10:10 am
Paul
I think you can use the marlin 1.1.8 for your printer
schlaflosin030
Post by schlaflosin030 » Mon Dec 24, 2018 10:30 am
Sorry but whre can i find a step-by-step Tutorial to update my new A10 with 3.0 Board and extra buyet BL-Sensor with the right Firmware.
It´s possible to update the firmware only via SD-Card (without USB conect)?
Ich habe so viele Fragen wo ich noch nicht mal weiß wie ich die verständlich auf englisch rüber bringe das ich mich über PN´s von Deutschsprachigen 3d-Druck-Rettern sehr freuen würde die die Nerven haben mir auch mal "dumme-Fragen" zum Thema zu beantworten. Ich kann zwar PC´s zusammen bauen und auch bis zu einem gewissen Punkt reparieren aber meine Programmiererfahrungen haben beim Basic vom C64 und TurboPascal (ein mal mit 6 mann "Mensch ärgere dich nicht" geschrieben dann nie wieder) in der Ausbildung auf gehört da ich immer mehr nen Praktischer Mensch war und es nicht so mit schreiben oder lesen hatte.
thank´s for help an
Marry x-mas
Chris
from Berlin
Post by William » Wed Dec 26, 2018 1:22 pm
thank´s for help an
Marry x-mas
Chris
from Berlin
You can check the FAQ of the A10 series printer section.
DjordjeN
Post by DjordjeN » Sat Dec 29, 2018 4:31 pm
As a new user I need some information please. In the instruction for A10 firmware you have stated: "You can find it on"Configuration and hex file",choose the correct configuration.h and replace the old one"!!! Copy the configuration.h file from folder Configuration and hex files to folder Marlin i.e. replace existing file?? Before uploading firmware or ...? Thanks for help. :)
Post by William » Fri Jan 04, 2019 9:18 am
Yes.You need to replace the old configuration.h before you upload.
You need to choose"3dtouch" or "no 3dtouch" file.
Locked
Users browsing this forum: No registered users and 15 guests
