GS2 Extruder stop working but the day before it was
Re: GS2 Extruder stop working but the day before it was
Post by William » Wed Nov 27, 2019 11:42 am
Hi, If you mean that the motor of the extruder is not working properly,
You can try to exchange with the motor wire and extruder motor wire that other shafts work normally.
Determine if this is happening due to broken motor wires;
Then you can try to exchange the drive plate of the other shaft with the drive plate of the extruder to determine if the voltage of the drive plate is too low to cause this.
