How to start Geeetech I3 Pro C in Repetier-Host
zhangxueyou
Post by zhangxueyou » Tue May 26, 2015 3:02 pm
Open Repetier-Host (Download link: http://www.repetier.com/download-now/), Access "Printer settings":
Set amount of extruder as 2, and set correct nozzle diameter:
Then you can control both extruders on Repetier-Host (Note:The extruder can not move unless the temperature is more than 180 degrees):
Slicer setting:
To have a good 3D item,you need to have a good slicer setting, and distribute jobs for 2 extruders:
Click "configuration" to access slicer setting:
For more details of sclicer setting, you can download the attachment to refer:
slicer settings for I3C.zip
(740.38 KiB) Downloaded 1941 times
ric chin
Re: How to start Geeetech I3 Pro C in Repetier-Host
Post by ric chin » Tue Jun 23, 2015 11:10 am
the software show is not even close to the current version available for the mac...can you up date your instructions for the current version.
TheFlyingDutchman
Post by TheFlyingDutchman » Mon Jul 06, 2015 2:43 pm
I'm also having trouble getting it up and running using a Mac. Instructions are unclear, and the programs look different on Mac.
poeytan
Post by poeytan » Thu Feb 04, 2016 6:48 pm
Hello, I am in possession of a geeetech 3i. Small problem during the execution of gcode with slice3r, fusion son are not contiguous. We can help by m m addressing the right configuration of the printer with a 1.75 thread.
Thank you very much
gpau
Post by gpau » Sun Feb 12, 2017 8:28 am
For two-color printing it is possible that I have to change here?
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
#define EXTRUDER_OFFSET_X {0.0, 0.00} // (in mm) for each extruder, offset of the hotend on the X axis
#define EXTRUDER_OFFSET_Y {0.0, 0.00} // (in mm) for each extruder, offset of the hotend on the Y axis
tokeandsmokeshop
marijuana edibles
Post by tokeandsmokeshop » Tue Jan 11, 2022 5:02 am
Keep up the great work thank you for posting
https://tokeandsmokeshop.com
