I got the error while trying to upload the firmware>
I loaded the .ino file into the software and clicked upload. (I think there was a total of 73 files that loaded in the Arudiono for the upload
Y- Axis Failing
Re: Y- Axis Failing
No, drag all the files into Arduino.
Re: Y- Axis Failing
All of the files are loaded into audrinio, 73 total
Re: Y- Axis Failing
Still displaying error? What version of Arduino are you using?
Re: Y- Axis Failing
Higher version doesn't have good compatibility, you can try to upload with Arduino1.0.1:
http://arduino.googlecode.com/files/ard ... indows.zip
Re: Y- Axis Failing
Loading via the lower version seemed to work,
I also have a problem with the slicer
I attached a photo of the issue
Please advise
Please advise
- 6-15-2015 8-18-13 PM.png (39.52 KiB) Viewed 10139 times
Re: Y- Axis Failing
You can refer to this page to set your printer in Repetier first:
http://www.geeetech.com/forum/viewtopic ... 21&t=16512
