calibrating
John LaBaff
calibrating
Post by John LaBaff » Thu Apr 23, 2015 7:26 pm
Ok I have my printer setup and ready to run. How do you set home positions. Also when I tried to start a print the x axis goes to the left and start to make a grinding noise please help
tonyflrb
Re: calibrating
Post by tonyflrb » Sun Jun 14, 2015 8:17 am
I also finished to assembly the printer, and has the same question. so every time I want to print something, do I need to reposition Z-axis?
because it is really time consuming if I have it all the way up!!
zhangxueyou
Re: calibrating
Post by zhangxueyou » Mon Jun 15, 2015 9:12 am
tonyflrb wrote:I also finished to assembly the printer, and has the same question. so every time I want to print something, do I need to reposition Z-axis?
Normally, you don't need to reposition z axis. How do you calibrate the distance between nozzle and glass?
Does the height of hot bed lower itself when you are heating the bed?
