printerboard set up
kryptonian
printerboard set up
Post by kryptonian » Sun Apr 05, 2015 3:00 am
Hello..Im having problem on how to programme my motherboard for the printer..I downloaded everything and cant seem to get it right..i tried downloading the driver but it says the driver is signature enforcement ..so my computer wont download it and when I plug the usb from the printer I hear a noise but cant see the driver..Dont you have an all in one software were I just install and my machine works..The lcd still wont display until I load and programme the board..please help..I thought once I build the 3d printer it will just be plug and print..im using a sanguinololu standard mega 2560+ramps 1.4 printrboard..I loaded all these requirements Software
Compiling environment: Arduino IDE
Firmware: Marlin
PC software: Printrun, Repetier-Host
Source
Printrun
Repetier-Host
Arduino IDE
Arduino IDE
Marlin
and im not sure if I did it in the right order...
zhangxueyou
Re: printerboard set up
Post by zhangxueyou » Wed Apr 08, 2015 3:52 pm
Hi, I want to know where you downloaded the firmware?
kryptonian
Post by kryptonian » Thu Apr 09, 2015 2:39 am
this is where I got the firmware from... http://www.geeetech.com/wiki/index.php/ ... et_Started
zhangxueyou
Post by zhangxueyou » Thu Apr 09, 2015 9:43 am
No, "Sanguino-0101r1.zip" is not Marlin firmware, it is a board type, you can't find sanguinololu's board type in Arduino IDE without it.
Other files are not firmware or correct firmware. Sorry for confusing you. We will delete them.
We don't share Marlin firmware online. If our customers need firmware, we will send them privately.
You can refer to this page to see more details:
http://www.geeetech.com/forum/viewtopic ... 14&t=16097
If you have no firmware, please tell me your email address, I will send you.
kryptonian
Post by kryptonian » Thu Apr 09, 2015 2:53 pm
i see..I guess i need the proper firmware then..If you could kindly e-mail it to me at kalelpuskas@yahoo.com..And if you have a step by step guide on how to install and set up my controller board i would appreciate it..
kryptonian
Post by kryptonian » Fri Apr 10, 2015 4:05 am
I don't know if im doing this right..On adruino..when I hit the upload button..it says compiling sketch..Then I see the upload bar..Then it says upload finished..
This is what I see at the bottom of adruino..It says
Binary sketch size 52,348 bytes (of a 258,048 byte maximum)
avrdude: stk500v2_receiveMessage () : timeout
avrdude: stk500v2_getsync () : timeout communication with programmer
P.s on the board selection I selected ardruino mega 2560 or mega ADk
zhangxueyou
Post by zhangxueyou » Fri Apr 10, 2015 9:06 am
If you mainboard type is Sanguinololu, the board type should be "Sanguino W/ATmega1284p 16mhz".
kryptonian
Post by kryptonian » Sat Apr 11, 2015 6:56 pm
IM LOOKING FOR THE BOARD TYPE ON MY ADRUINO ("Sanguino W/ATmega1284p 16mhz) AND I CANT FIND IT...I PASTED THE SANGUINO FOLDER IN THE ADRUINO HARDWARE FOLDER..NOW WHEN I GO TO THE BOARDS SECTION AND LOOK FOR THE BOARD TYPE ITS NOT THERE..WHAT AM I DOING WRONG?
zhangxueyou
Post by zhangxueyou » Mon Apr 13, 2015 3:39 pm
You did not save the board type of Sanguinololu in Arduino IDE.
You can refer to this page to learn how to upload firmware:
kryptonian
Post by kryptonian » Tue Apr 14, 2015 2:21 am
where do I save sanguine..I pasted the sanguine file in the adruino hardware..i followed the instruction but its not appearing on the boards selection list..Am I saving it wrong?
