Problem reading temperature Rambo Board
daxer70
Post by daxer70 » Tue Jun 24, 2014 1:29 pm
Hi again…
some months ago I bought a Rambo Board 1.2
I've just mounted the rambo board and there is a problem temperature reading. I've attached a standard epcos 100k thermistor and the board isn't reading the values (I got always 0). The thermistor is working, tested it on a RAMPS.
I'm us gin latest Marlin firmware
I've tried using T1 connector but had the same problem. Can you help me ?
thanks
techsupport
Re: Problem reading temperature Rambo Board
Post by techsupport » Tue Jun 24, 2014 2:20 pm
Hi daxer70
The rambo board thermistor wiring method was: Extruder connect T0,hot bed connect T2;
Temperature is normal, the board can be heated.you can try it again.
Any more question are welcomed.
Best regards.
Email: forum@geeetech.com
daxer70
Post by daxer70 » Tue Jun 24, 2014 2:27 pm
I connected thermistor hot end to T0 and when I switch on the board I get an ERRMIN temperature error.
Looking on repetier host the temperature is zero.
The same hot end thermistor connected to a ramps return 25 degrees
So I think that there something wrong with the board.
What should I check?
daxer70
Post by daxer70 » Wed Jun 25, 2014 12:54 pm
May be, a diode D1 problem may cause this problem ? In rambo board schematics I couldn't find that diode.
techsupport
Post by techsupport » Wed Jun 25, 2014 2:20 pm
You can try to put the T0 short circuit use wire,
If return max degrees, That's means T0 normal.
daxer70
Post by daxer70 » Thu Jun 26, 2014 7:34 pm
yes short-circuiting I get max Temp. the thermistor is working I've tested it with a multimeter and I get a value of 93K (it is a 100k Epcos thermistor) and I put it on a RAMPS board and the thermistor is reading the correct temperature…
daxer70
Post by daxer70 » Thu Jun 26, 2014 7:41 pm
I've tried with to different firmwares on the rambo board (Repetier and Marlin)
techsupport
Post by techsupport » Fri Jun 27, 2014 9:32 am
Yes,The thermistor was ok. Resistance value and temperature are related.
I saw you describe the board is missing a diode D1,Is missing when you received the board,
There are other obvious missing parts? I guess is it possible to caused by external forces.
daxer70
Post by daxer70 » Fri Jun 27, 2014 2:42 pm
I've added board photos in may G+
here is the link
https://plus.google.com/photos/11271648 ... unzlaKFxAE
at first sight, I can't see any other part missing
any other suggestion ?
techsupport
Post by techsupport » Fri Jun 27, 2014 5:40 pm
I have seen you send pictures carefully,the board is complete, no missing parts.
and short-circuiting T0 you get max Temp,That's means T0 normal.
I think maybe a thermistor and firmware does not match.
Can you tell me your thermistor type and firmware source you use?
Users browsing this forum: No registered users and 1 guest
