Z axis and easy print problem
Vanessagcal
Post by Vanessagcal » Mon Nov 19, 2018 5:28 pm
Hello, I recently finished the assembly of the prusa i3 pro W, but while doing the first print I faced the following problems:
https://www.dropbox.com/sh/0dwvcim5j1nc ... pcfaa?dl=0
The z axis is having trouble moving up and down, it gets stuck and makes a lot of noise. I tried taking out the threaded rod and noticed that one motor is moving first and then the other so it destabilizes. Also, the x axis is not moving much.
The problem with easy print is that when I start the job nothing happens, the extruder and the heat bed stays off, I don't know if it's a connection problem, I tried heating the extruder and the bed manually and it worked.
