Z axis issues
Neil
Z axis issues
Post by Neil » Tue Feb 13, 2018 8:12 am
Ok I have my i3 pro b now printing....sort of.
My main issue is I keep getting intermitant binding on the left side lead screw, some.time it happens and some times it's fine.
I have checked everything mechanically multiple times and i can't find a physical reason for this to happen.
Could it be I need to up the power of the stepper motors to cope with the weight of the extruder carriage or could it be some thing else?
Re: Z axis issues
Post by William » Tue Feb 13, 2018 3:29 pm
1.You should adjust the level of X-axis right and left is same
2.Add lubricating oil
3.Increase the voltage of A4988
(Turn the top adjustable resistance screw)
Neil
Re: Z axis issues
Post by Neil » Tue Feb 13, 2018 4:12 pm
Thank you for the reply.
Just a quick follow up question. Is there an optimum power setting for the motors and is it possible to set it too high?
Neil
Re: Z axis issues
Post by Neil » Thu Feb 15, 2018 3:41 am
Well I've finally taken the infernal thing apart and found that not only are the threads on the brass T nuts badly cut but the lead screws are massively out of tolerance to the point where I can't even recut the threads with a die cutter because they are so large.
Off to the hardware store tomorrow for more threaded rod .
Not impressed with quality control
Re: Z axis issues
Post by William » Fri Feb 16, 2018 11:48 am
Have you tried to contact the related sales for sending you the new parts?
algernon
Re: Z axis issues
Post by algernon » Wed Nov 07, 2018 6:03 pm
Hi, since the instalation of the new version RepetierHost_2_1_3, I have Z engines that slam and jump steps with slicer Cura and it goes well with SLIC3r (printer geeetech I3 M201)
I contacted repeater facebook, here is their answer:
Adjust z jerk, acceleration and max z speed in firmware to values that work for your printer. I guess cura has no limit and relies on firmware to adjust to limits.
How do we do that ? on I3 M201 not having an open source card
Re: Z axis issues
Post by _kaktus_ » Fri Nov 09, 2018 2:26 am
Hello.
If you want to contact me on PM.
I can try to reconstruct your situation.
How fast do you print :?:
Re: Z axis issues
Post by William » Tue Nov 13, 2018 9:32 am
You can check it on "control">"Motion".
Then you can calibration
algernon
Re: Z axis issues
Post by algernon » Wed Nov 14, 2018 5:58 pm
Thank you both, I sent a message to kaktus
