GPRS SHIELD ERROR 3
pinkic81
GPRS SHIELD ERROR 3
Post by pinkic81 » Tue Jan 19, 2016 9:26 am
Hello, I bought http://www.geeetech.com/wiki/index.php/ ... e_Examples with arduino uno and I tried to use the source code of that link (send2pachube) and give me a +CME ERROR: 3, so i decide to try another source code
Code: Select all
This code is refer to the example of PachubeClientString of Arduino
libraries and example of GPRS Shield, it is only a test code for the place
with stable GPRS signal.
Different countries may use different APN name, this example is work in China,
we use APN name of CMNET, please do not use it in your country.
Circuit:
* Battery positive port attached to analog in 0
* Temperature&Humidity sensor attached to analog in 5
* GPRS Shield attached to digital 7,8
Cosm API for TCP : https://cosm.com/docs/beta/socket_server/
#include <SoftwareSerial.h>
#include "DHT.h"
#define APIKEY "1HxJIs8IcwN45Lj3RbViMbXUw-ySAKxNNm91amRLNU9BZz0g" // replace your pachube api key here
#define FEEDID 91687 // replace your feed ID
#define DHTPIN A5 // Temperature&Humidity sensor port
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22 (AM2302)
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
int buttonState = 0; // current state of the button
const int buttonPin = 2;
SoftwareSerial GPRS(7,8);
DHT dht(DHTPIN, DHTTYPE);
float humidity,temperature;
long previousMillis = 0; // will store last time data was updated
long interval = 300000; // interval at which to upload data (milliseconds)
void setup()
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
// pinMode(ledPin, OUTPUT);
// pinMode(ledpinsim,OUTPUT);
GPRS.begin(19200);
Serial.begin(19200);
dht.begin();
TcpSettings(); // Setting network connection
void loop()
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
DataSend2Cosm();
delay(100);
void TcpSettings()
GPRS.println("AT+CSQ"); // Attach from GPRS serivce
Response();
GPRS.println("AT+CGATT=1"); // Attach from GPRS serivce
delay(3000);
Response();
GPRS.println("AT+CSTT=\"internet.ideasclaro\""); // Start task and set APN
delay(4000);
Response();
GPRS.println("AT+CIICR"); // Bring up wireless connection with GPRS
delay(4000);
Response();
GPRS.println("AT+CIFSR"); // Get local IP address
delay(4000);
Response();
GPRS.println("AT+CIPSPRT=1"); // Set its prompt echo '>'and shows "send ok" when sending is successful
delay(4000);
Response();
GPRS.println("AT+CIPQSEND=0"); // Set normal data transmitting mode
delay(4000);
Response();
void DataSend2Cosm()
GPRS.println("AT+CIPSTART=\"TCP\",\"api.cosm.com\",\"8081\""); //Start up TCP connection
delay(4000);
Response();
GPRS.println("AT+CIPSEND"); // Begin send data to Pachube through TCP connection
delay(4000);
Response();
// Request Syntax for TCP Socket Connection Type
GPRS.print("{");
GPRS.print("\"method\" : \"put\",");
GPRS.print("\"resource\" : \"/feeds/");
GPRS.print(FEEDID);
GPRS.print("\",");
GPRS.print("\"params\" : {},");
GPRS.print("\"headers\" : {\"X-ApiKey\":\"");
GPRS.print(APIKEY);
GPRS.print("\"},");
GPRS.print("\"body\" : ");
GPRS.print("{\"version\" : \"1.0.0\",");
GPRS.print("\"datastreams\" : [");
GPRS.print("{\"id\" : \"Temperature\",");
GPRS.print("\"current_value\" : \"");
GPRS.print(temperature,1);
GPRS.print("\"},");
GPRS.print("{\"id\" : \"Humidity\",");
GPRS.print(humidity,1);
GPRS.println("\"}]},");
GPRS.print("\"token\" : \"123\"}");
// End of Request Syntax
GPRS.println((char)26); // After sending AT+CIPSEND ,tap CTRL+Z to send data
delay(3000);
Response();
GPRS.println("AT+CIPCLOSE"); // Close TCP connection
Response();
void Response()
delay(100);
while(!GPRS.available());
if(GPRS.available()){
while(GPRS.available()){
Serial.write(GPRS.read());
and the serial monitor data here
Code: Select all
AT+CSQ
+CSQ: 23,0
OK
AT+CGATT=1
OK
AT+CSTT="internet.ideasclaro"
+CME ERROR: 3
AT+CIICR
+CME ERROR: 3
AT+CIFSR
10.14.65.46
AT+CIPSPRT=1
OK
AT+CIPQSEND=0
OK
AT+CIPSTART="TCP","api.cosm.com","8081"
OK
AT+CIPSEND
+CME ERROR: 3
{"method" : "put","resource" : "/feeds/91687","params" : {},"heAT+CIPCLOSE
+CME ERROR: 3
The error i'm getting crazy because i read about in several forums and shoudn't be problem, some times after power down and power on several time no givme error, this is very frustrating i hope anybody can help me, thanks in advance.
