Newbie asks for help !!!
Posted: Tue Jul 13, 2021 5:01 pm
by Der Wäller
Hello colleagues, I am new to 3d printing and I need your help.
My A30 Pro prints the figure supplied by Geeetech in super quality!
When I slice other models with Cura, threads and stripes can be found on the outer contour. Is too much filament inserted? Where in Cura can I regulate it?
Thank you in advance!
MFG from Germany
Re: Newbie asks for help !!!
Posted: Fri Jul 16, 2021 10:12 am
by Admin
Hello, this is generally due to the effect of temperature or the setting of the layer height is too high. It is recommended that the layer height is 0.2mm. If you want a more exquisite model, 0.1 is also possible, but the printing time will also be doubled.
Posted: Mon Jul 19, 2021 9:31 pm
by Der Wäller
Hello admin, thank you very much for your help! The printouts are now very good after I added the Cura profile of the A10T in Cura. Then I made a few settings in this profile and now my A30 Pro prints as I wanted it to.
All the best and good luck!
Hermann :idea:
