A20T start code
Ade O
A20T start code
Post by Ade O » Mon Apr 20, 2020 1:01 am
hi im having a bit of weirdness happening ive set up cura to extrude at 208 and disengage the two extruders setting it up as 100,0,0 all is fine it comes up to temp then as it starts it resets to 215 and extruders reset to 34,33,33 I mean come on I have been trying to wrack my head over this gone through the settings on the machine itself but ive got no where, help please
Ade
Ade O
Re: A20T
Post by Ade O » Mon Apr 20, 2020 1:41 am
ok so is it poss for me too remove the settings for extruder temp and mix extruder mix from the start code without causing too many problems and will it then keep the settings sent via cura
Zaphod_Beee
Re: A20T start code
Post by Zaphod_Beee » Sat May 02, 2020 7:39 pm
it looks this should help: (I did not try it yet)
viewtopic.php?f=117&t=69683
I have te same Probem.
Good luck!
