The TMC2208 about A20T Firmware
Admin
Post by Admin » Wed Dec 04, 2019 2:51 pm
:D Hi,Guys.
the firmware about the A20T TMC2208
you can download from this link :
A20T_TMC2208.rar
(121.39 KiB) Downloaded 1076 times
giogio
Re: The TMC2208 about A20T Firmware
Post by giogio » Thu Apr 09, 2020 7:52 pm
HI i need same for A30T please
have you the uncompiled firmware please?
thanks
Post by William » Fri Apr 10, 2020 9:24 am
Hi, thanks for your feedback.
now the firmware is being tested.
mlabis
Post by mlabis » Sun May 03, 2020 3:56 am
Hi friends, is there A20T firmware with 3D touch and TMC2208 support?
Post by William » Mon May 04, 2020 10:33 am
Hi,we do not have the corresponding firmware, you can directly exchange the wire sequence as shown in the figure.
Bobertino
Post by Bobertino » Wed May 20, 2020 3:23 pm
I would like to upgrade to TMC2208, but have BlTouch.
Are you saying that if we swap the wires it will be supported?
Do you know when we will have a firmware with TMC2208 and 3DTouch support?
Post by William » Thu May 21, 2020 9:39 am
Hi,the firmware has nothing to do with the driver, you can still use the firmware that supports 3Dtouch.
Bobertino
Post by Bobertino » Fri May 29, 2020 4:28 pm
I have installed TMC2209 https://www.amazon.co.uk/dp/B082FBLH62/ ... _at_prodpg
I'm trying to tune the VREF and all I get is 4.88v. Potentiometer makes no difference on output.
I know it could be a defective product, but I would be surprised if 5 of them are defective.
Any suggestions on what might be the problem?
Post by William » Fri May 29, 2020 6:19 pm
Hi,can't adjust the voltage?
Bobertino
Post by Bobertino » Fri May 29, 2020 6:38 pm
Correct. I can't adjust the voltage.
My guess is that the VREF pin hasn't been wired correctly, I found someone else with the same problem.
They probably work fine, but I have no way to adjust them without the VREF pin working.
I'm going to return them and get a different brand.
