I'm new to 3D printing. Recently, I had a problem with the hotend so I replaced it. But I don't take care about the 2 fans placements. Since, my printer often pause printing without error message. I just have to select "Resume" to continue but it's a little bit annoying for long prints.
I suspect I mount the 2 fans in a wrong way. Actually, the 2 fans take the air from outside to the hotend.
Could you confirm the direction of the air flow ? (I wonder if left fan take air to the hotend and the right to outside, but not sure).
Sorry for my stupidity -_-!
Question about A20M fan placement
Re: Question about A20M fan placement
Hi, The fans inside the hot end housing are on both sides of the hot end.
Is for cooling fans,
One left and right.
One left and right.
Thanks for answer.
My question is more about the direction of the air flow of each fans. Is it from inside the hotend to the outside or vice versa ?
I tried to draw my question, see files below
What is correct ?
What is correct ?
- IMG_20200103_230315.jpg (89.07 KiB) Viewed 11297 times
- IMG_20200103_230347.jpg (82.14 KiB) Viewed 11297 times
Hi,it is 2.
No. 2???
On my A10M it was configuration No.1 from factory (2018/10 model). Warm flow is going to printed model.
So what is right in reallity?
A10 Slic3r profile: here
I don't think the fans on the sides go to the model. It's the 3rd fan's role, the one with a duck to cold the print. Maybe I'm wrong ?
Maybe.
I am waiting to official Geee answer about fan direction...
I want to change the fans, in order to get something quieter.
Does someone has good links to quieter fans?
Power supply's Fan :
60*60*15 mm / 12 V / 0,2 A
MotherBoard's Fan
50*50*20 mm / 24V
Best regards,
Christophe
MotherBoard's Fan
50*50*20 mm / 24V
Best regards,
Christophe
Look at my signature
oh, Jarda3d is right.
