perfect thanks... the servo pin is 27?
New A20M Model ?
Re: New A20M Model ?
i have a different one kind of connexion on my A20M printer head.
Can anyone tell me how to connect 3D-Touch on this head?
Thanks,
H.
Thanks,
H.
- IMG_9378.jpg (235.81 KiB) Viewed 24120 times
Same model same question, how to plug the 3Dtouch ?
Hallo,
upper are grounds ...
Wi
Wi
Hello
I have my A20M since a week now ... and only did two print
I bought the 3dTouch ... but when looking the way to do on my new version ( V4 ) of the A20M ... and all the issues ( failure ) I see about it
I just wonder if I should not return it , and buy the original BLTouch ...
What do you think ?
Good idea ? useless ? bad idea ? ( and why )
What do you think ?
My A20t bought in Spring has this too
They changed the hotend slide, appearently.
Instead of flexing off the nose you can also replace the endstop holder with a modified one which places the endstop switch further left.
I use the one included here: https://www.thingiverse.com/thing:4257275.
Hello
Could someone provide me the values of the setting as it is "out-of-the-box" for the A20M V4 ?
Especially the one in menu "Control / Motion"
- Velocity
- Acceleration
- Jerk
- Estep
Thanks a lot
for the story summary : ( see my point about estep below )
I tested my A20M out of the box , with correct prints
I installed my 3dtouch , following the Geeetech explanations ( video )
To get sticking prints to the plate .. I had to fine tune the z offset ( as documented and explain in lots of places )
I did it with the
application "pronterface" (https://www.pronterface.com/)
following this video ( https://youtu.be/y_1Kg45APko
( I did it a second time , as it was a little bit too low / touching the bed ... )
The next issue was that all my prints ( even the gcode already tested ) were really under extruded
I did the estep calibration ... I had to change the value from 395 to 931.6 ( yes ... that much
to get rid of the under extrusion issue.
- Velocity
- Acceleration
- Jerk
- Estep
Thanks a lot
I did it with the
Hello everyone
Hello guys, thanks for your photos how to connect bltouse, it helped me
Btw
I got something cool for you , if you are student
Grades are very important for students, but many students do not have so much energy, so do I, to complete every learning task, especially those about programming in languages such as Python. EssayWritingService is an institution whose purpose is to complete different problems of classmates, especially those who have accumulated many years of experience in cs writing https://write-essay-for-me.com/write-essays-for-money . Because our company employs a lot of writers in this area, we can complete your assignments within the relatively urgent deadline.
Btw
