USB driver - always unknown
Bernd
Post by Bernd » Sun Dec 09, 2018 4:19 am
I just can not get it to connect the A20M via USB to my computer Windows 10. Is there possibly a trick? I downloaded the CH41SER. But it comes always unknown USB device error 43! Can someone help ?
Bernd
blakilox
Re: USB driver - always unknown
Post by blakilox » Sun Dec 09, 2018 1:31 pm
The Driver I used
http://www.wch.cn/download/ch341ser_zip.html
Though I have this on Windows 7, what I had to do was use the Ardwino IDE to edit the Baud Rate in the Firmware down to 115200 (The Max windows seems to support) so I'm talking about the Marlin firmware, editing the configuration.h file and reduce from 250000 to 115200
so first download and install the latest ArdwinoIDE, then get the Marlin Firmware for the A20M open it in Ardwino IDE, Edit that Configuration.h file and push up the firmware change to the printer (Yeah i know it's a chicken and the Egg thing though this seemed to work, so I wondered if the IDE has its own driver)
If you look at your Devices, the Comm port, the Max Speed, does it match the Baud rate listed in the A20M Control Panel? After I did that change it worked, perhaps in Linux it can go as high as 250000 though seems not in windows, or at least not for that driver
when you make that change in the Firmware you should see the Baud rate change reflected in the A20M Panel, then it should match the Baud Rate in the Windows Com device that you are using
I would suggest Geeetech send out the A20M's at 115200 as default, or at least look at what is going on there for a better fix for windows users, because it dosent seem to work strait out the box for Windows user (How about include a Software CD for your users, that may save them like a Week of frustration) its not like the slower speed will make the printer go faster so go for Safety settings please Geeetech
Post by William » Mon Dec 10, 2018 12:22 am
Bernd
Maybe somewhere have a short circuit.
You can check them at first
Post by _kaktus_ » Tue Dec 11, 2018 2:13 am
Hi William.
In my opinion, colleague was installing the wrong driver. :roll:
Post by William » Tue Dec 11, 2018 1:23 pm
Hi William.
I am checking the user manual and I found some mistakes.
I will contact them soon~
Post by _kaktus_ » Tue Dec 11, 2018 11:23 pm
Let the world of 3D printing be better with Geeetech.
:D
Post by William » Wed Dec 12, 2018 10:05 am
Bernd
Post by Bernd » Wed Dec 12, 2018 4:33 pm
Thanks for your help but it has been found that the 2560 board is broken and therefore no connection via USB could be made.
Bernd
