i've got a strange problem on switch on of printer.
If i print something and then i switch off the printer at the end of that, next time i boot i've got a messagge on lcd:
Code: Select all
POWER OUTAGE
- resume print
- cancel print
- switch on
- print some gcode from sd
- switch off (at the regular end of print)
- switch on... (even after a lot of time)
- PROBLEM
It happen only after a print.
If a switch on, then switch off and switch on again, it doesn't happen.
I've changed a lot of end GCODE script but the problem still remain.
Can you help me?
