Strange message on switch on
meldro
Post by meldro » Fri Apr 24, 2020 5:19 pm
Hi everybody,
i've got a strange problem on switch on of printer.
If i print something and then i switch off the printer at the end of that, next time i boot i've got a messagge on lcd:
Code: Select all
POWER OUTAGE
- resume print
- cancel print
RECAP:
- switch on
- print some gcode from sd
- switch off (at the regular end of print)
- switch on... (even after a lot of time)
- PROBLEM
It happen only after a print.
If a switch on, then switch off and switch on again, it doesn't happen.
I've changed a lot of end GCODE script but the problem still remain.
Can you help me?
Re: Strange message on switch on
Post by William » Fri Apr 24, 2020 5:34 pm
Hi,its normal.
This is the function of continuous power off. If the power is off, the next time you turn it on, there will be this prompt.
You can choose to continue printing or stop printing.
meldro
Post by meldro » Fri Apr 24, 2020 9:13 pm
Hi,its normal.
Hi William,
thanks for reply.
Do you mean is it normal even if i've properly completed my print (without any error or power problem) ? (sorry for that question but i'm pretty newbbie about 3d print :) ).
Post by William » Sat Apr 25, 2020 10:23 am
Yes,you may have disconnected the power directly when you turned off the printer.
