Cura config file for MC2
Posted: Sun May 14, 2017 10:43 pm
by Blobabee
Hey All,
I just got my Mecreator 2 (previously had a Monoprice / Maker Select Plus) and I'm hoping someone could upload their config file for Cura. I would really appreciate it.
Thank you in advance!
Re: Cura config file for MC2
Posted: Tue May 16, 2017 9:28 am
Hi,here is my Cura config for MC2,and you can modify these values accoring to your actual situation when necessary.
Posted: Tue May 16, 2017 12:39 pm
by Blobabee
Thanks so much William! I'll give it a try. You rock! -Bob
Posted: Tue May 16, 2017 12:50 pm
by Blobabee
William wrote:Hi,here is my Cura config for MC2,and you can modify these values accoring to your actual situation when necessary.
Mecreator 2 Cura Config.zip
William, which version of Cura is this config file from?
Thank you
Posted: Tue May 16, 2017 1:41 pm
The cura config file is created by the Repetier Host.Here is the picture.
- QQ截图20170516133904.png (94.62 KiB) Viewed 31692 times
Posted: Tue May 16, 2017 2:06 pm
by Blobabee
Ahh ok. Cura doesn't recognize the file as a Profile or Machine (printer) so that's why I couldn't find a way to import it. Unless I'm missing something? (I'm not using Repetier at all). The file would end in .curaprofile
Posted: Fri May 27, 2022 4:28 pm
by Ubedt
Thank you for the information
