Cura config file for MC2
Blobabee
Post by Blobabee » Sun May 14, 2017 10:43 pm
Hey All,
I just got my Mecreator 2 (previously had a Monoprice / Maker Select Plus) and I'm hoping someone could upload their config file for Cura. I would really appreciate it.
Thank you in advance!
Re: Cura config file for MC2
Post by William » Tue May 16, 2017 9:28 am
Hi,here is my Cura config for MC2,and you can modify these values accoring to your actual situation when necessary. :D
Mecreator 2 Cura Config.zip
(1.3 KiB) Downloaded 1592 times
Blobabee
Post by Blobabee » Tue May 16, 2017 12:39 pm
Thanks so much William! I'll give it a try. You rock! -Bob
Blobabee
Post by Blobabee » Tue May 16, 2017 12:50 pm
William wrote:Hi,here is my Cura config for MC2,and you can modify these values accoring to your actual situation when necessary. :D
William, which version of Cura is this config file from?
Thank you
Post by William » Tue May 16, 2017 1:41 pm
The cura config file is created by the Repetier Host.Here is the picture.
Blobabee
Post by Blobabee » Tue May 16, 2017 2:06 pm
Ahh ok. Cura doesn't recognize the file as a Profile or Machine (printer) so that's why I couldn't find a way to import it. Unless I'm missing something? (I'm not using Repetier at all). The file would end in .curaprofile
Ubedt
Post by Ubedt » Fri May 27, 2022 4:28 pm
Thank you for the information
