SD CARD format and file upload
mecreator2
Post by mecreator2 » Sat Apr 29, 2017 5:01 am
He guys,
Im having only a MAC and Windows7 computer without SD-CARD slot
i hope somebody can tell me the following :
sd card formatting : FAT / FAT32 /ExFAt etc ?
and what kind of file format upload/copy to the sd card : gcode, g or something else ?
The problem is the following, i insert the card and it shows me the card, but not the files on it(i uploaded gcode files)
Then i tried via repetier host (the latest) to upload it to the card which was inserted into the printer.
Any tips or tricks are appreciated .... its a 1Gb SD Card
And ive got the MeCreator2 ;-)
Me Creator 2 / Repetier host / Slic3r
Instagram : www.pictaram.com/user/mecreator2/4934215835
rotormansa
Re: SD CARD format and file upload
Post by rotormansa » Mon May 01, 2017 1:32 am
FAT32 is the format the card needs to be in. FAT also worked for me, but FAT32 will allow the use of larger cards.
I am using a 1G and an 8G without issues.
When you upload the file you must include the extension .gco.
I initially was using the SD card a lot but found it easier to just attach an old PC to the printer and print via the USB cable.
Good luck
mecreator2
Post by mecreator2 » Mon May 01, 2017 1:36 am
@rotormansa
thanx for the info !!
Well i actually also always printed via cable because direct access etc ..... but i just wanted to try it and it didnt work at all.
Ill give it a try and see ;-) thanx !!!
