STL files for delta rostock mini G2&G2S and I3 printer
hello,every one.here is the STL files for delta rostock mini G2&G2s and I3 printer, check the attachment.you can download it to print some parts if needed.
Re: STL files for delta rostock mini G2&G2S
Thank you for these. Great work.
Thanks so much!
What I could really use is the templates for top and bottom frame plates. I would like to modify to cut acrylic for a larger frame that would also accomodate a 12" non-heated plate.
Sorry, but this isn't true. The Platform piece in the archive is only for the G2. I need the G2s platform. It has a flat spot for the micro-switch to be mounted and it has a guide for the Allen Key to slide into.Eric wrote:hello,every one.here is the STL files for delta rostock mini G2&G2s in the attachment.you can download it to print some parts if needed.
Is there any chance you can publish the G2s Platform piece ?
They are the same for G2 and G2S:
- QQ截图20150916200331.png (29.07 KiB) Viewed 38325 times
Re: STL files for delta rostock mini G2&G2S and I3 printer
Just putting together the dual head Rostock Mini G2S.
Ive been a bit heavy handed with the LCD controller mount pieces and broken one around the nut trap.
Part no. #A9
Are the STL's or laser cutting files available so I can print a replacement on my other 3d printer.
Gordon
Part no. #A9
Gordon
Thank you.
And ive now got some more search terms to use.
I didnt know which other model geeetech printers share some same parts.
Gordon
Gordon
What exactly do you mean?gordonendersby wrote:Thank you.
Gordon
I know the printer I've got as a geeetech rostock mini g2 or g2s.
On that thingiverse part it's listed for rostock 301.
When I searched thing I verse I didn't find it with just what I knew it as.
This model 301 is either a slightly different printer or maybe an earlier version of what I've got and shares the same LCD support part.
So nest time I'll add 301 as part of my search .
